First of all the engine ran fine until the rubber water pump propeller was replaced. (by a repair facility) After the propeller was replaced the engine would not idle. I removed the carb and did the point and spray to try to clean out all passages. Put the carb back together and it did idle, but when I put it in the water it would not perform under the load of engaging the outdrive. Removed carb again to see if we missed something but after spraying all passages out again there was no difference in engine performance. The fuel filter is ok, spark plugs have 2 hours on them at the most and the oil level might be a little low but is not overfilled at all.
I should add after the propeller was install the engine would not idle but would run under the load of the out drive and move the boat well but didn't seem to be as well as it was before the propeller replacement. Any suggestions would be great because I am running out of ideas
