Tohatsu M15A prop shaft housing
costakyle
I'm about to have the prop shaft housing welded. I'm worried that the heat will damage the bearing's on the inside of the housing. Should I remove them? If so How is that done? I've removed the oil seal.
P.S. I'd buy a new one if I could find one. I'm paying a welder around $100 to fix the old one.
pvanv
Re: Tohatsu M15A prop shaft housing
If you want to remove the forward bearing, you casn use a special long-arm puller, or fill the cavity behind the beaqring with #2 grease, insert the prop shaft, and rap it with a mallet to drive it out hydraulically.
