I ran the boat for just over 6 hours brought it home and commenced the fresh water flush. Everything was going well until 20 seconds into the flush. The low oil pressure/water over temp alarm went off, so I shut her down and started troubleshooting. Verified oil level and double checked water inlets were not clogged. Hooked up motor flush and tested again; same results again 20 seconds into flushing alarm goes off. Decided to start troubleshoot some more and ended up changing the oil and filter. Cranked her back up and no alarm, YAY!!!
Fast forward approximately 24 hours, same scenario. Went out for 6 hours (no problems at all), brought boat home and commenced fresh water flush. Guess what happened... you got it alarm went off again.:mad-new: This time I changed out all the soft materials in the water pump i.e. impeller, gaskets. I cranked her back up and still got the alarm. The oil level is good and I am getting good water discharge. I will change the oil and filter again and see if that makes the alarm go away again. If anyone has any other ideas on what might be causing the alarm to continue to go off I would be glad to hear them.
