Tohatsu mfs5cs fuel pump cleaning
Bahti
Hi, I completed 50 hours and i need to clean fuel pump. Does anyone know how to to clean it?
pvanv
Why do you want to clean the pump? Here is what it looks like:
Sea Rider
Yep, where have you read that needs to be cleaned ? As long the carb is spotless and motor is running top no need to perform such work. Run carb dry till motor dies if will be used from time to time. Carbs are delicate and complex mechanisms, should not be fingered if not needed.
Happy Boating
