Tohatsu Peeing Issues,.
Sea Rider
Just for the record. A Tohatsu 18 HP owner with cracy ideas that states that marine engines doesn't need to be flushed after each outing began having overheating and poorly peeing issues.
The engine has just 75 metered running hours from out of the box, 2 places to look after. Peeing hole obstruction or bad cond impeller. Immediate LU impossible to be removed, the spring pin that holds the joint shift rod is completely seized due to salt and rust formation. Will need to be drilled out.
Removed complete crankcase assy, lower crank and upper pan water passages were a salt mess, sprayed pure vinegar overdose, let soak for an hour, with Japanese sushi wooden sticks and extreme patience rubbed all water paths to inmaculate clean condition. Scraping with a metallic sharp object could remove metal bits from water paths that will inevitably led for salt deposits to start forming there.
To my surprise found that the peeing hole located at upper pan’s end is not a straight one, meets into a chamber with lower peeing path that exits through upper leg side. If you poke a wire, W40 or carb cleaner cannula through lower peeing hole you won’t see it exiting through upper pan, a plastic tie & wrap which is more flexible will work his way through upper pan, internal chamber and exit through leg’s side. If you insert same cannula, tie & wrap through peeing port will only reach internal chamber and won’t make their way through pan which connects lower crankcase water paths through pan.
If experiencing engine poorly peeing issues, fully tilt engine, spray an overdose of W40 or vinegar, long soak is mandatory along air or high pressure water blast through peeing hole. Having crankcase removed is much faster to clean as you can poke back & forth a tie & wrap from both sides while turning TW 360? to remove salt with its back rugged surface. Thermo and pan’s gasket being at a very bad state was mandatory to change for my peace of mind and to go along the entire work performed.
Took advantage to fully re torque complete powerhead along carbon guard decarbonization with engine on, now engine is purring as a kitten and peeing as a teenager again. Idiotic boater and $ 150 after has learned the bitter lesson….
Bottomline : Flush your engine after each outing, your engine will be eternally thankfull…
Happy Boating
TwoRivers
Re: Tohatsu Peeing Issues,.
Luis,
You take the best pictures.
Rob
Sea Rider
Thanks Rob,
15 years doing digital photography helps too. Good pics showing complete details should go along when trying to explain something. As the saying goes : A pic is much better than 1K written words.
Happy Boating
Sea Rider
Related Topic : Water on Pan
Whle cruising a water line is seen peeing rear of pan, there's a small hole for draining water when rinsing pan, should not be water flooding pan whatsoever when engine is on. Issues to check, old blown base gasket, silicone has not been applied to gasket when changing new one, lower powerhead bolts badly torqued. None of them as base gasket is new, a thin silicone coat has been applied to both sides and torqued to specs. Have seen this issue 3 previous times, this one is for having it in consideration or will drive you nuts trying to find the flooding pan cause.
Due to Idiotic owner not having flushed his engine from new, the lower internal water seal that lives opposite the thermostat has internally corroded so much that when appying juice to engine starts leaking there, a small leak now, will worsen with time and will flood pan worst. You can use pan to keep live bait there....
Quick reapir, apply silicone under lower powerhead and hope lesak is sealed and pan remains dry, worst scenario pull powerhead again and apply a thin coat of epoxy cement under round water seal to stop water leak forever, this seal has a no part available code nor listed in the spare parts manual. Probably will need to install a new base gasket, hope not.
Happy Boating
greg daigle
also try salt termantor its a flusing liquid sold at marine dealers run eng. in tank with this stuff it removes all salt through out eng.
Sea Rider
Greg,
Salt termantor or Salt Away type products applied on this particular example won't do much. To have it clear, no matter how long you rinse your engine with fresh water after each final use, in the short term sallt will be formed in microscopic thin layers one on top of the other, these products should work well under this condition. Will have my doubts if egine is heavily salt crust clogged, in that case removal of all water gaskets is mandatory to expose all water paths, a mechanical salt removal procedure will be your best option.
Happy Boating
