Sea Rider
Thread starter- Joined
- Sep 20, 2008
- 12,345
What is the best method to flush a new Tohatsu MFS 15C HP 4 strokes which sits on an engine bracket way back of a 30" sailboat, it's a AFT model (electric start & trim) the sailboat is attached to a buoy far from a marina. Flushing posibilities :
1-Ear muffs with hose attached to on board tap water bucket, muffs always lose pressure & water while flushing no matter how tight they are against lower tail.
2-Tail Flusher coupler with hose attached to same on board tap water bucket. Will need to seal with duct tape side water inlets and under cav plate water strainner to avoid salt water intrusion.
3-Proper bucket to place tail deep enough for a good flushing filled with on board tap water.
For points 2-3 will need to raise tail out of water, place coupler or bucket, lower leg and start engine for at least a 3 minute flush. Is there any other creative alternative ? Sailors with flushing experience are needed...
Related Tech Issues:
1-For proper breaking engine purposes, is it the same to break a new engine following owners manual hours recommendation wether the engine is pushing a light versus a heavy sailboat ?
2- E-8, is it advisable to follow same E-10 recommendations, run cab dry after each use, use the amount on tank needed for that outing ?
Happy Boating
Happy Boating
