too much oil?
17rogue70
if you premix and add too much oil what are the bad and good ,if there are any? i know foul plugs ,smoke like crazy .
Faztbullet
Re: too much oil?
If its way too rich it can lean out the engine....
boobie
Re: too much oil?
There's room for arguement on that one and it's been well discussed on this forum.
Silvertip
Re: too much oil?
The real question is how much too much oil did you add?
17rogue70
Re: too much oil?
about 16 oz too much in a 30 gal tank
fragged
Re: too much oil?
Faztbullet is spot on ..
i posted this to another thread
If you run a higher oil content you will be weakening the fuel/air ratio , this in turn will raise the cylinder temps as you will be
running a lean mixture.
Eventually if the mixture is too lean because the oil content is too high you will burn a hole in a piston or seize the engine as the cylinder temps get too hot.
It is a myth that putting more oil in a 2 stroke helps the engine through better lubrication.
Rich
