tools i made and used for outdrive service
bigskiohio
stand is 2x4s and dolly i had.
pressure gauge a friend made for me ,gauge is a 0- 30 fuel gauge ebay $9.00
shrader valve ace hard. $2.00, scrap aluminum 1.25 round,3/8-16 thrd.
uses merc gasket and 3/8 oring. Used a hand pump to pressurize.
3/4 pvc pipe i use for grease blow gun as i dindnt want to put my spline grease in gun as it would damage other bearing as it is a sliding grease.so i stick it in tube and load with grease ,stick i in coupler and blow, worked great did that 3 or4 times and greased shaft . the other is alignment shaft from ebay $35.00
rocket350
Re: tool i made and used for outdrive service
Nice! Great job. Funny how common sense can make things simple. Maybe you should run for some type of public office!! ha ha...
bigskiohio
This is the hose i use to run with outdrive off. 3/4 hose glued to black water intake hose , i just put in water port a few wraps of electrical tape snugs it up other end has hose repair end to hook to hose.
