Top bearing is not getting enough oil, crossflow 90hp
Guys,
Since i had 2 cilinders scored, i opened the engine investigating and checking everything,
i noticed the lack of oil at the upper bearing. It has nothing to do with the 2 cilinders but i know this is not supposed to be like this. Bearings need oil.
All intake canals are open, but it just seems the oil is not traveling up:(
Is there something i can do to help the oil migrating to the top?
Re: Top bearing is not getting enough oil, crossflow 90hp
Hi there commanders,
i really need some help here, to get this solved. I tried the search button with no luck.
How does this top bearing get his oil feed?
clanton
check and clean all recirclation hoses and nipples, the nipples in the block/intake are one way check valves. routing of hoses depends on year of engine. Early engines should be upgraded to 1990s hose routing.
Haffiman
In addition to the check-valves, check that nipples in the by-pass covers are open as well as all channels in the intake manifold. Do not use any sealer on intake gaskets!!
PS: It may has to do with scored cylinders as if no excess fuel from bypass covers, no lubrication to upper bearing!!
emdsapmgr
Do an autopsy on the upper carb. Make sure there is no debris in the carb jets, esp the two mains in the upper bowl. You'll need to pull the jets out for a visual inspection. Also remove and inspect the needle and seat.
1946Zephyr
Is there an oil line on the side of the block? If there is, check and make sure it's not broke or clogged up. A lot of motors will have a return line that feeds the top bearing, from the bottom.
Joe Reeves
See the oil feed hole in the top main bearing housing... first picture, facing straight up, very visible. Now, flip the forward crankcase housing over and follow the oil feed.
