Puncheon50
Thread starter- Joined
- Jan 4, 2017
- 48
Ive never done this.
Id be leaning towards the powerpack at this point but id check Voltage from sensor first
Not sure I did any of this right but, Charge coil output came out at a consistent 320. As for the Sensor Coil, i set my Multi meter to the V Wavey AC thing and with the DVA, all three connections tested at .4 like the manual says. Don't know if that's the right way to do it because the manual says you need a CD Voltmeter set to S and 5???. I could'nt figure out the power pack. I tried with the DVA and got zero readings then realized the manual says nothing about using a CD Voltmeter. I just used the straight multi meter and was getting a 450 volt reading on all 3 connections. The manual says 260 or higher. I am not sure if I did something wrong or if running at 450 is too hot. Maybe thats why I had a no start on the lake last week because the power pack over heated? After all that I went back and checked the resistance to the sensor coil and the damn B jack came back at 18 which, I guess, is good. Can I ellimate the powerpack as an issue?
