Top gimbal bearing o-ring on drive shaft sheered off?
void7910
Hey all. I was re-installing my alpha one gen 2, on my second attempt after having the paper gasket pop out. Anyway, I noticed to top most o-ring (closest to drive) had an entire section sheered off all the way around. It was like a thin o-ring was cut off it and just hanging out on the top bit of the shaft. Replaced that one o-ring, rest looked fine and were just installed on my first attempt at install. Any idea idea what caused that o-ring to fail like that?
Bt Doctur
The large square O ring is installed with bellows adhes, weatherstrip adhesive, or contact cement in the housing first. If dislodged water can enter the drive
void7910
This wasn’t the big o-ring. :) second small o-ring on the drive shaft.
dubs283
If its the o ring closest to the u joints thats one of the two gimbal bearing o rings used as dampeners between the gimbal bearing race and splined input shaft
Shearing it off isn't too big a deal but it could indicate a misaligned gimbal bearing or too large o.d. of the o rings
Light grease or oil helps them slide better through the race at drive install
void7910
I’m a bad boat owner and didn’t check alignment before both install attempts. However, no major issues getting it on or off once I get the splines aligned after a couple attempts.
Interesting about OD. It was a legit Mercruiser kit so I assume things were the right size. Both gimbal o-rings looked about the same and only one broke.
My only other thought is that it was some kind of a weird manufacturing error. Maybe existing rubber stuck in the mold or something.
crazy charlie
I have had mercruiser outdrives for over 30 years and never had that happen on any o rings.If you are going to replace o ring and reinstall ,I would recommend getting a glob of grease on 2 fingers and reaching into the bell housing and smearing some grease onto the surface of the gimbal bearing casing.not a fix but a possible precaution only.You can also grease the rings and make sure you grease the splines. Charlie
void7910
Good idea about greasing the contact points of the gimbal. Definitely greased everything else, o-rings, splines, big o-ring, u-joint middle section, front of drive that goes into bell housing.
I also have never seen an o-ring come apart like that. Took me a while to figure out where this little thin o-ring came from before I notice a strip out of one of the gimbal o-rings all the way around.
