Warlord1337
Thread starter- Joined
- Feb 17, 2021
- 5
Hey guys Ryan here,,first time posting. Have a 1997 120 hp Force outboard on a quantum 170xd I started tinkering with. Have had it for a couple years but only have taken it out after I first bought it (ran fine) and then it was sitting for awhile. Motor was seized but after spraying some wd40 in the cylinders and set for 24 hours I was able to break them loose fairly easy. Turns over and runs good again.
Have cleaned the carb, checked thermostat and replaced impeller. Noticed the tell tale didn't have "great" flow so I checked compression. #1 120psi #2 135psi 3&4 had around 150psi pulled the cylinder head to do a once over and check gasket. Found top piston has more "play" then the rest. Cylinder walls look and feel good on all 4.. guess my question is how easy is it to change out the top 2 pistons? My guess is the rings are going out and I've found kits on ebay for $70 (ring and piston). Can you access the rod bolts from the intake side or would you have to break the whole block apart? And can I just hone the cylinders a little, I can feel no pits or any damage to the cylinders. Not going to spend a lot on this boat but if a can do some easy and low cost preventive maintenance I'm fine with that.
Also bottom piston looks like it is what seized the engine after sitting. Looks like moisture got between the piston and the head then by chance was fully compressed while sitting for a couple years, by the looks of the scoring. Am I looking at that right? Have worked on trucks and motorcycles, but first real outboard though.
Found one imperfection on the gasket and have no clue how it could of happened seeing as there is no hole on the the head for the water to go...it will be getting changed out anyway but figured someone might know..
This is a fresh water only engine by the way, overall a very clean engine just don't want to do more work then I have to with a engine that runs fine and could last me a couple of years....
