mtboatin
Thread starter- Joined
- Jul 27, 2012
- 169
Hello all. I recently purchased a 1994 Cobalt 272. This boat is equipped with a 7.4 GL PMDM and B2 props. Slowly going through things. Boat has sat close to three plus years with a full 98 gallon tank. Fuel smells fine but you know....three year old fuel. Added multiple high end fuel additives and stabilizers, a VP fuel filter, and will be slowly (literately) burning through the tank to get new fuel in. Took it out and found idle low in the 450 range. Bumped up the idle with set screw to close to the 600 mark and after a few hours found it a little low around the 500 rpm. My main question is on WOT. I know it's almost 5000k with fuel and water but only seeing 32 mph both on speedo and GPS. RPMs are at 3600 ish. I'm thinking it should be closer to 4500 and probably closer to 45 mph. Boat came from Havasu and has been in NW Montana for the last 5 plus years so there was a change in altitude back then. Can't imagine I would need to drop to B1s. Hole shot seems good again for boat of this size. Other than burning the fuel and seeing what happens with fresh and doing some carb tuning is there anything else I'm missing?
