Top speed of a 140 hp in a nineteen
luva63
Could anyone here give me an idea of the top speed of a 140 ? Would it be around 40 mph? I know most didn't have speedometers ,but figured someone might have checked it with a gps.
bajaunderground
Re: Top speed of a 140 hp in a nineteen
Need more info...prop, gear case ratio, boat weight, elevations (this one is easy)...
ziggy
i'd think a little less than 40. my 165hp gets up to 41-43mph, gps, depending on the day.
i run a 19p aluminum prop.
luva63
I have my eye on a couple nineteens right now fairly close. One is a 140 hp and the other is a 165 hp. Haven't seen either in person yet as I have been trying to sell an old boat to make room for a Nineteen. I have an old nineteen brochure that states they would run over 40 mph with the standard engine. I guess that would be the 120 hp? If a 120 would push one that fast,a 165 would be around 50??
ziggy
here is a thread i started awhile ago wanting to know speed differences. maybe that'll help. someone with a 120 responded in it.
all i can say is what i've observed with mine. max speed i ever got out of mine is 44mph @ 4400 rpm. which is 100 rpm faster that wot spec. i've never seen close to 50 out of mine. when ever i do a speed run my 1st statement holds true, always, assuming all is well with my boat. my speeds are gps and as far as i'm concerned, a fact about the speed (41-43mph) of my nineteen. original drive (1.65:1) and engine.
the varaitons in my speed i think are about air temp, humidity. when both are high, i go slower. also when i do the speed run. 1st run of the day or wait till end of day after the engine is really warmed (heat saturated) up. again, slower speeds when heat saturated.
luva63
Ziggy, I think your right on this. A 120 is capable of approx 37mph, a 140, 40mph, a 165,44mph. I know for a fact, conditions play a huge part in how fast any boat will go. My funliner will vary 3-4 mph depending on wind ,waves and current. I don't know if either of these boats I'm looking at are waterlogged or not,but I'd be willing to bet they prolly both are to some degree. One has a blue hull and top and the other has a standard white hull with blue top. Still debating that.:)
