Top speed?
summitlt
I have a 74 Glastron V156 sportster with a 85hp merc inline 4. 15' 6" long by the way.
What do you think the top speed should be? With the right prop?
tashasdaddy
Re: Top speed?
if v hull agree with 35-40, if tri hull cut it 5mph.
summitlt
Re: Top speed?
It is a Tri-hull. So tri hull is slower? Was thinking it would be inbetweena v and a flatbottom
chiefalen
Re: Top speed?
My 2 cents, to stay within the recommended rpm range, and the largest prop and with a gps you tell us.
For example, rpm say can't go over 5000 rpms, i don't know what your motors max rpms should be, this is a example, and a pitch on the prop say of 19.
That would give you the best top end.
Now as in everything with boats there is a compromise.
Want to pull skiers or tubers, the hole shot will suffer.
So you may want to go down 2 degrees for a better hole shot.
So the question you have to ask yourself what do i want to do with the boat?
Fish, get to the fishing hole faster?
Pull skiers ?
Now i always carry a spare prop for that very reason, a pitch propeller 2 degrees lower than the max rpms prop.
So when i go out in the morning to fish i get to the other side of the lake faster 9 miles away and of course in a hurry.
Then when it's time to put the poles away and the other kids want to ski i throw on the prop with the better hole shot.
Hope i was clear. And good luck.
Frank Acampora
Re: Top speed?
Glastrons before 1980 were a light, fast hull. V156 should be rated for a 90. Prop her correctly and with the Merc 85 she should go around 45 with 12 gallons fuel and driver. Be disappointed with less. Figure 36-40 with two passengers. Small boats respond negatively to extra weight. Still will be an excellent ski or wakeboard package though.
You may need to raise the engine about 1 inch on the transom to get full performance.
Want more info? Go to classicglastron.com
45Auto
Re: Top speed?
My 1980 Mark Twain trihull with a Merc 120 runs mid 30's with one person and 5 gallons of gas on board. Never seen over 35 MPH. But it also averages over 6 MPG which amazed me!
RotaryRacer
Re: Top speed?
25-30 tops with that body style
Umm. I think it will be more than that.
I had a 15' '73 Saf-T-Mate tri-hull with a 70 HP Evinrude that did a little over 35 mph. That Glastron with an 85 HP Merc should go at least that fast, probably a little faster. I wouldn't be surprised at all if it did 40 mph.
The wetted surface of a tri-hull on plane isn't that much different than a V-bottom. They can be pretty quick. In the mid 70s they were building boats very light which helps also.
summitlt
Re: Top speed?
Best I got out of her was 37mph this summer, loaded. But the prop is dinged and I don't know the condition of the motor yet. Havent done a compression check or anything. Just seeing if I was in the right area.
RotaryRacer
Re: Top speed?
Was that GPS speed? What RPMs was the motor running at that speed?
It really doesn't sound too far off from what would be expected for that combo.
