top speed ?
Texasmark
Re: top speed ?
I had a glass boat built in the early 60's. Name was Taylor craft. It seems that at that time some mfgrs didn't use foam floatation at all. They "sealed" the deck to the hull making an "airtight" chamber below the deck which was supposed to suffice for safety's sake.
After having a similar problem one day, I felt that the boat was getting way too heavy and upon digging around I found a small screw on the transom at a height that would put it below the deck.
I pulled the screw and the thing drained for half an hour. Periodically after that I'd pull the screw and drain it. I never did find where the water was getting in.
HTH,
Mark
mr roach
Re: top speed ?
buzz and mr88 again thank you for the information and sorry for the delay in responding we had a dog emergency at my house. I will do some research and get this boat to the best it can be or find an alum hull to outfit. Again thank you to all and good boating
Texasmark
Re: top speed ?
My only restoration and my current boat are deliberately alum for the same reasons.
Mark
