Torque spec on omc inter gimbal plate
m2hunt
I had to replace the gimbal gasket does anyone know the torque spec it is a 1990 3.0 140hp
Bt Doctur
Re: Torque spec on omc inter gimbal plate
Not sure of the question , there is no gasket on a gimbal bearing?
m2hunt
Didnt replace the bearing i need to know the torque spes on the inter gimbal plate that bolts it to the transom i replaced the gimbal gasket to the transom
Bt Doctur
go into the adults only section , sure theres a manual download there for omc
m2hunt
That was no help does anyone know
m2hunt
yes thats what i am looking for
m2hunt
I thank you for the info but if its not one thing with this boat its another now the drive shaft wont go threw the gimble bearing I had a hard time gettig the drive out of the gimble when i took it apart and the motor was already out I never had problems like this with any of the merc i owned
Bt Doctur
A cobra drive, like mercruiser need to be aligned with the engine coupler.
Difficulty removing a drive can be corrosion or mis-alignment.On installation is more a alignment issue
