Torque Spec, Starter Bolts, 115HP, 2001, V4, 4 stroke.
vjsimone
Looking for the Torque Spec for the Starter Bolts.
Thanks
boscoe99
Then the model is an F115TL/XRZ model. Why not say so? It is right on a plate on the side of the motor.
Torque for a Yamaha 8 mm bolt is 3.6 pound-feet.
vjsimone
Thanks.
Seeing the boat for the first time Saturday.
One of the 2 motors is missing a starter.
I found a used starter, going to install the used starter motor to check the compression. Hoping the bolts are there, but if not I will use the bolts out of the other motor after I check that one out.
