Torque specs for B100
Dumar
I am replacing a rotten exhaust pipe on my Honda B100 because fumes in the engine compartment would not allow the motor to run with the cover on. Getting the pipe off required a fair amount of disassembly. I have new parts in hand, but require torque specifications for the head and associated manifolds. Does anyone have these numbers? Thanks.
wundurdog
Re: Torque specs for B100
The torque specs for the BF100 are as follows: Cyl Head 8MM bolts are 16 ft lbs. Other standard torque specs are: 5MM bolt and nut/4 ft lbs: 6mm bolt and nut/7 ft lbs: 8mm bolt and nut/17 ft lbs: 10mm bolt and nut 27 ft lbs.
Dumar
Thanks for the specs, wundurdog. With respect to the gaskets: I've heard some people fit them dry and others use sealer. Any thoughts on this subject?
