Re: torquing bolts, nuts
There is no such thing as a 'marine' torque wrench. But you're not using the right torque wrench for the job. At the far end of the bottom scale, most wrenches are hopelessly inaccurate - it could be off by 50% easily. Going beyond the bottom end of the scale makes a bad situation worse.<br />Invest in a 0-250 inch/lb (0 - 21 ft/lb) or thereabouts torque wrench and use it for all the fasteners in it's range. The big one is good for the flywheel nut, connecting rods and such but you'll need the little one for other things.
