Re: Total rewire
Here's a quick start:<br /><br />1. Use marine grade wire. It is tinned and more resistant to corrosion.<br /><br />2. Connect wires with crimp connections. Wire nuts are a big no-no. When you crimp, crimp well.<br /><br />3. Seal all connections with adhesive coated heat shrink. The marine environment is murder for corrosion. Especially salt water.<br /><br />4. You need to fuse any wire coming from the battery withikn 7 inches of the battery. (Except engine starter wire if you have a sterndrive.<br /><br />5. BTW - Was that a marine alternator? I needs to be a marine alternator.<br /><br />6. Fuse panel is a good idea.<br /><br />7. Unlike autos, boats have no good ground. YOu must run a good ground wire.<br /><br />8. Remember, this is a 12 volt system. You must not only size the wire to be able to carry the amperage, but be concerned with voltage drop. ON a 12 volt system trying to keep to 2% or so total voltage drop is tough.<br /><br />9. If you have fuses, you really need to carry spare fuses. Think about where you will have these so they will always be handy.<br /><br />10. Vibration is a big killer. Make sure to support the wiring well.<br /><br />I'm sure others will have more to say.
