Totally baffling !!! Impeller replaced !! And not pumping
kinger952
stop trying to pump water from a tote. if it works, you are lucky. these pumps are flood to prime, meaning the water level must be 6" or more above the impeller or use muffs.
to get water 6" or more above the impeller, the boat must be in a tote big enough to get the drives submerged.
Unit is under water 10" still nothing I posted a video or trying to
kinger952
Not spinning g the shaft unless spinning the motor... correct?
What are we spinning withe the drill?
I actually heated up a 7/8 deep 12 pt socket and. Tweeked it until it fit snugly on shaft then welded bolt thru end and using 1/2" Dewalt vari drill. Works nicely
Fits tight as to not damage shaft !! Almost like it was made for it
Dubed
Now I'm baffled...
Are you spinning the prop shaft while in neutral?? I'm not an ace technician like most of these guys on here but don't think that will work
kinger952
Now I'm baffled...
Prop is OFF and it is in neutral !!! Plugged oil hole on fin and added oil
Not the prop shaft but the main sgaft that goes into the upper unit gear
Jarvis25
I am having a similar issue. Does the copper tubing need to have a decent seal where it connects with the power head to allow for a good vacuum for the stream? I blew into the pisser with a mouthful of water while my outboard was in the water and I could hear air bubbles where there was an air leak just under the power head. Trying to figure out if this is a big deal or not before I start to tear that part of the motor apart.
Start your own thread. Don't hijack threads
Rick Stephens
Apologies. It seemed relevant to the conversation but I can look elsewhere for an answer.
Not really, this is the Merc inboard outboard forum. Apparently you are asking about an outboard. Different beast for the most part. No need to apologize, just ask away on your own thread.
tank1949
ALPHA 1ST GEN Second new one with all housing parts and o-rings & gaskets and dunked in large tote full of water made a custom socket to fit in 1/2 " variable speed Dewalt drill spun both directions and NOTHING !! BY LOOKS OF THE BRASS IN THE IMPELLER THE KEYWAY DView attachment 367894View attachment 367893View attachment 367894OESNT SEEM TO BE SPINNING
I'm at a loss I've done dozens of these with ZERO issues till now .
All water pathways are clean and clear .
Enclosing 2 pictures 1 of old imp and 1 of new
u sure brass or keyway hasn't spun out.
kinger952
Pretty sure it hasn't spun but I will paint inside of impeller and double check this time. Thanks
kinger952
Going to look at 1 more time then install and take boat to launch and dunk it there /fun off engines ans see if water comes out thru hull exhaust ? Hopefully it will if not new=used lower I guess - nothing else I can do .
It is against all physics why has not been pumping in tote . But I've seen stranger things . 😕
