totally confused
penguinsfan
hey guys i'm totally new at this boat motor thing, i've had my boat for about a year now but i'm having some problems. i had a cracked manifold got that fixed and now i have a problem with my ignition. i went to canadian tire and bought a universal ignition switch in the auto parts with the 3 screws on it like my other one but my old one had posts. i hooked the 3 wires red, yellow and purple but there is 2 purples, left one off. now when i start the boat it starts ok but when i put it gear forward or reverse it stops, then if i put it in neutral fast it will start again. should i buy a boat ignition or is it something i'm missing ? and what should i do with the other purple wire.
thanks
Don S
Re: totally confused
Put the purple (Ignition) wire back on and try it. You can't just leave ignition wires off and expect things to work.
What are we working on? Things like engine, year, type of drive etc.
penguinsfan
its a mid 90's 4.3 mercruiser.
the problem with the purple is there is 2 wires how do i connect them both on ? join them together and put them both on ? :)
If both purple wires went to the same terminal before, then yes they both need to go to the same terminal again. If you have screws on the switch can you put a ring terminal on each or both in one ring terminal and attach to the screw?
penguinsfan
now when I was screwing around with it i did have both purple wires touching each other, kind of wrapped it around so i assume it was connected. i just got a universal switch for it should i get a boat one or it shouldn't matter.
thanks
Ayuh,... Put 'em on the same screw....
penguinsfan
ah ok when it stops raining i'll give that a shot. so I can just twist them both together and join em with ring terminal :)
thanks guys
penguinsfan
ok
now when I put it in gear it doesn't die but it sounds like you're trying to start it when its started, kinda like when you do it in a car then I have to turn it off with the key. I can't believe all of this just from changing an ignition again. it is a universal ignition I got at Canadian tire. should it be for a boat ?
I tried both ways of hooking it up 3 screws one to the battery and the other two switching back and forth still starts the boat both ways
penguinsfan
touched red and yellow wires together and boat turned on.
any ideas guys do you see something obvious please help.
thanks
Don S
any ideas guys do you see something obvious.
Yeah, stop messing with it. You have no clue what you are doing and you have the wiring all screwed up.
Post a clear picture of your ignition switch that shows where the wires are.
penguinsfan
ya I know don but I figured 3 wires how hard could it be right lol I guess I was wrong. do you think I should get a boat switch or the universal should work.
i'll try and take the picture tomorrow.
Don S
The universal may work, hard to say which one you actually have. Do you have a link that shows the exact switch you have?
penguinsfan
no sorry I know its from Canadian tire :) i'm going to get a boat switch we have a dealer 20 minutes away and go from there. my brother in law is good with this stuff so i'll get him to do it with me.
thanks for looking don sorry for bein an idiot.
