touch up paint
licorice
I have a 1994 spectrum aluminum boat.I am looking for touch up paint for a few scratches. The color is marine white spray paint number 5h180. does anyone know where I can order this type of paint. Thanks Licorice.
Woodonglass
Re: touch up paint
Tracker bought Spectrum so you might contact them and see if they could give you a lead on the paint.
licorice
Re: touch up paint
Thanks I tried there site and no luck.Actually I have tried everywhere and no luck guess I should be asking what color matches marine white?? Thanks Licorice.
Woodonglass
Re: touch up paint
I would Call them and talk to their technical support. You will get much better help that way.
Yacht Dr.
Re: touch up paint
For spray application or touch up with a nail polish brush ?
Is it a base coat clear coat ?
Nothing matches Marine white aside from Marine white. You can get lucky and match up a car color white or another boat color white. Again do you what it in a spray can or just a can of white where you have to spray it yourself VIA gun .. ? Clearcoat.. ?
Application method would help here.
YD.
licorice
Re: touch up paint
well lol I found a spray can in the box that came with the boat. Of course it's empty but I thought it would be a good reference in my search. here is the exact label. TOUCH UP PAINT US MARINE 5H180 BOAT WHITE ENAMEL US MARINE CORPORATION 105 MARINE DRIVE HARTFORD WI 53027. 13 OUNCES. Yep that's it but could not find nothing when I searched the web but it a very old can lol. Thanks licorice
GT1000000
Re: touch up paint
The only suggestion I can come up with is to try an Automotive Paint and Body Supply house in your neighborhood...take the can, and if there is a part on the boat with the same color that you can remove and take with you, most places can match it for you with a similar or compatible type paint...maybe even special order a pint for you in a marine formulation...
Sorry, it's what was left of my .02?...:redface:
Good Luck...
licorice
Re: touch up paint
Thank you so much for the help 2 cents is better than nothing. We have a local shop here in this small town and I will go check it out. Thanks again:Licorice
