mwe-maxxowner
Thread starter- Joined
- Jun 20, 2012
- 825
Sometimes it is a bit difficult to get my boat into neutral. When it is it takes a bit more effort than it should to push it from fwd to neutral. So that it may overshoot neutral and you actually go past it toward reverse and have to then pull back up slightly to neutral. It is not too awful bad on my boat, but my fathers boat does the same thing, only MUCH worse.
The boat is an 86 Dixie hustler 188 with 4.3 v6 and alpha one outdrive.
Any ideas what I should check?
Also there is a flexible black rubber hose coming out of my boat with the outdrive. Mine is cracked and torn. What is this and how much should I expect to pay a boat mechanic to fix it?
Trying to get any odds and ends I need done to the boat so I can have it in tip top shape for summer.
