Re: tough stains
In this months edition of boating on page 85, there's an article on Tidy Boat Man. <br /><br />The Works toilet bowl cleaner=create 4:1 solution of water and the works. work for water - stained fiber glass hull, plastic cowler of outboard, engine's metal drive shaft housing.-- just spray on and wipe off. you'll be surprised how quickly it works.<br /><br />Lemon Juice - citrus eliminates fishy smells., rinse livewell with alot water, next, pour half bottle of lemon juice concentrate and fill your well with fresh water. Run liquid through the pumps. also use on cutting boards, scrub board with salk, wet towel, rinse with then wipe with lemon juice.<br /><br />dawn dish soap- cut through oil, funk of your bilge water. use alot, foam it up, hose it down, bounce it around, let it set, drive around, it will coagulate, remove chunk by hand, dump or pump it overboard!<br /><br />Lemon spray Pledge- clears up the plexiglass, blurry plastic vinyl on your bimini top. use as many appls as necessary. IT WORKS... beats buying a new bimini top. it is a nice (oxymornon) also helps beads water, spray on, wipe off. now you'll know what yo're really seeing.....<br /><br />easy off oven cleaner- removes painted=on names from your fivberglass. easy off on a rag will remove it faster than you can say.....@#$@#$@#$. wipe away excess, then rinse.<br /><br />coca-cola. battery corrosive stuff. dont forget to rinse.<br /><br />baking soda - BEST CLEANER !!!! for mild corrosion on battery. one part poowder, 3 part water. also a all purpose cleaner. 1/2 cup of baking soda, 1/2 cup of vinegar, and 1 cup ammonia with 1 gallon water warm. pour into spray bottle. work for hullstain, deck stain (leaves) slso genral head cleaning and cabin mildew, stains, waterstain on fabric. <br /><br />I've used FEBREZE odor remover on my cushions in my cuddy. Took it out, cleaned it well, then i sprayed febreze and let it dry...repeated as necessary....and the mildew, old cushion odor was almost gone...<br /><br />threw in car freshener deodorizer, odor eliminator from autozone and the cuddy was nice for the ladies....<br /><br /><br />hope that helps. good luck
