So here it goes the long story? two weeks ago I decided to go for a leisurely boat ride on the boat with my tower of power 1971 1350 serial number 3037534. Got her up and running let it warm up and proceeded to burn some of the cobwebs out
across the lake it will run an easy 5800 rpm+ on my boat but I try to keep it below 5400. After a few short minuets of that I decided it would be fun just to put around the lake and look at some of the houses surrounding it and just enjoy the scenery. So keeping it at a slow pace about 2000 rpm or so I was circling the lake when the motor started to run and sound not so good. Thinking that it had probably loaded up on fuel I opened It back up across the lake now the max rpm was 5000 and the engine felt like it was missing. So I headed back to the ramp to do a little diagnostics and pulling one plug wire off at a time found # 3 hole was missing. Later that day I ran a compression test and #3 hole now had no compression
and signs of detonation in the number 3 hole. Knowing at this point the engine had to come apart to make further diagnostics I pulled and split the power head finding #3 piston rings broke and missing and the # 5 piston rings broke and missing. The #3 hole has some light scoring and the rest of the cylinders are fine. So I plan on replacing the # 3 and #5 pistons and rings, honing out all 6 cylinders and putting it back together with maybe some new reeds? I?m looking at some Boyesen power reeds 65312b65 to replace the originals with.
The questions is why did this detonate. I bought this motor not that long ago and went though it and did some preventative maintenance replacing the upper and lower crank seals, timing belt wires plugs and floats needles and seats, I did not completely disassemble the carbs but did look at the main jet witch is .080 and appeared to be clean like the float bowl so I did not go farther with the carbs. I also did a link and sync like found in this form with max timing set to 21 degrees. I was running 89 octane 10% ethanol fuel mixed 50:1. This motor also has a new water pump impeller and pee?s fine and did not feel hot.
What did I do wrong, how do I fix it so it dose not happen again. I?m thinking maybe I need to back the timing off more and maybe run an octane booster in the fuel? Ethanol free premium fuel is hard to get now a days to is it better to run 87 octane without the ethanol or run the higher octane to beat the detonation and run the ethanol.
Also a pon disassembly of the motor I found out that the #3 and #5 pistons had been replaced once before because they were of the 2 ring design and had the power port hole and the other six are the three ring design and have now power port hole? Not sure If the different pistons are to blame but they all appear to be of the high dome verity because the dome was taller then .650 and measured about .750 not sure if the replacement pistons had something with it failing on those cylinders or if its something else?
Also how loose should the reed blocks fit around the crank shaft it seems to me that they should fit a little tighter than they appear to but I?m no expert so what is normal?
I?m sorry for rambling its past my bed time.
Thank you for any help and input/advice
