Re: Towing 3500# with a Colorado?
Thats cool man, but just so you know, your truck would have likely done it no problem at all. It really depends on what gear you have in the rear. If its the 373 then your rated all the way to 5500lbs. But it also depends on which five banger you have...the 3.7 or the 3.5? 04, and 05 models have the 3.5ltr. Newer have the 3.7ltr.
If you have the 242 rear then your capped at your original estimate. The truck will likely have the locker from factory, and your in luck..its a true locker. Not a posi or some crap like that. Easy way to tell, put one wheel in greass, and one on the pavement..gun it and see if you leave a black line on the road..lol. If so...your set. If not, I'm sorry...lol.
Now, as far as stopping...well if your careful it will do the job without a problem as the brakes on colly's and canyon's are pretty beefy for what the truck is... And dont worry about the tranny, just stay out of over drive and if your really concerned, either swap out the servos for covette servos, or call PCMSFORLESS in moorseville NC... They can tune your pcm to shorten your shift times and also make them firmer. Really makes life better anyway as you will get a nice power adder there too. And its cheap only like $125...
anyway at least now you know...later.
