Re: Towing a small empty trailer
Nothing like tossing a cat amongst the pidgeons. <br />Trailer tyres, and all tyres for that matter, are designed to run in a certain pressure range for carrying a load. <br /><br />To suggest that the tyres remain at that pressure when no load is being carried is simply ridiculous.<br /><br />So therefore, it would seem prudent and sensible to deflate the tyres to their minimun safe working pressure in these circumstances?<br /><br />If you take the time to check, you may be surprised to discover that under no load or minimum load conditions, most tyres will happily run all day at between 8-10 lbs, and the additional benefits gained, like greater tyre footprint, less rigid tyre wall leading to better tracking and safer handling are actually endorsed by tyre manufacturers in these circumstances.<br /><br />Of course, you could leave the tyre inflated as if it was carrying it's normal load, and watch it bounce across the road each time it hits a bump. Then when you get it home you can put all the bulbs back in their sockets. <br /><br />At lower pressures, the tyres act as a greater part of the suspension. More give in the tyres, less trailer bounce.<br /><br />This is why tyre pressures are recommended. It depends on the tyre construction,(radial or bias) the load, road conditions, trailer construction,(springs or not) etc.
