catfishhoward
Thread starter- Joined
- Oct 9, 2009
- 136
I have a 2012 VW minivan, FWD, 3.6L V6, 283 HP, 6-speed automatic/shiftable,curb weight 4500lb, towing 3600lb**. I'm buying a pontoon at is 20' and a total wieght of 2000lb, trailer is a tandem trailer 900lb so a total of 2900lb.
I only have 10 miles to tow so that's not a problem, it's getting up the ramp I have a little concern with. Any tricks to help drive up the wet ramp? The most problem I've read is that the front wheels come off the ramp when you pull up the ramp, I would think my 283hp would pull up the ramp as long as my front end is push down, wouldn't a weight distribution hitch help push the front down giving me good traction? or how about a stinger hitch, I was wondering how it would work when it's the crown of the ramp at top, it might push the van up? I thought about a extension bar so my van stays out of the water but the ramps are usually wet all the way up from dripping of other trailers. I also thought about putting a heavy duty trailer jockey on the trailer, If I get stuck on the ramp I can block up the trailer wheels, pull the van up to level ground and pull the trailer up the ramp with a tow rope. I have noticed that there's not much tongue weight on some the boat and trailers I've looked at, I was wondering is it better to keep the weight in the boat in front, over the axle or in the very back of the boat while loading and unloading?
I have a van and I keeping the van. I attached some photos. The ideas are just for launching the boat, I don't plan of travelling with any ideas.
