demarko210
- Joined
- Jan 2, 2015
- 655
I always have my overdrive to the on position. When I turn off I get the O/D off light. I was wondering if anyone turns overdrive off while trailering their load?
That's a 5R55S, which dates back to the A4LD. I would for sure pull it out of OD. Towing in OD would get the trans a bit warm, and then they tend to have solenoid problems that you will feel with a reverse delay and eventually get an extra neutral when you loose reverse
Are you saying when not towing your boat your rev's are 1500 and with the boat at the same speed its 1800?My boat is 2700# 230 Sea Fox WA. I am not sure if the Manufacture gives the weight on full tank or not. Highway I am usually going around 55-65mph at about 1800 rpm. No load hold around 1500 at that speed. That is with the OD on. I will run with OD off I would suspect the rpm will climb with OD off. Thanks everyone, I will look for my manual.
Tranny had 250k miles on it bought it with 98K. I decided to rebuild because every time I change the fluid I loose gears when setting on a incline. It would go away over time but I know it should not happen and my plan was to put miles on a new tranny with the boat. If I would not have changed my fluid the last time I probably still have that 3500 in my pocket and would not have done the rebuild yet but my plans we to do the rebuild. It just came sooner than expected. Tranny was load but still shift ok before the rebuild. Now I dont even notice that the gears are changing when pulling the trailer. I had them do the main seals and oil pan gasket with the tranny.Are you saying when not towing your boat your rev's are 1500 and with the boat at the same speed its 1800?
If so, I suspect the difference is your torque converter is not locking up when towing.
Not locking up = heat = bad.
Maybe that's why you needed your tranny rebuilt?
Yes when I am riding on the highway flat with the boat doing 55-65 its at 1800-1900. With no load it rides at 1500 at those speeds. On a hill it jumps timing at about 2800-3000. I try to keep it under 3200k if I can.
That would drive me nuts… see nothing above 1800 unless the engine brake kicks in.Traveled about 55-65mph and it rpm maintained at about 2200-2800 rpm all the way down and up the highway.
Your truck pull the load under 2000 rpm when you travel?That would drive me nuts… see nothing above 1800 unless the engine brake kicks in.
