Trevthefox
- Joined
- Sep 25, 2018
- 101
Hello everyone,
Was out on the water and noticed some water in the bilge. Had previously thought it was coming through a thru-hull fitting but I tracked it down near the y-pipe. (Check out the video). I've been searching through videos and parts diagrams to see if I can locate the most likely cause of the issue. My best guess is a leak through the lower bellows. I had recently replaced the lower bellows and was pretty sure I did the replacement correctly. However this last outing makes me think I'm wrong.
Couple questions. My other guess would be through the y-pipe connection. However when looking at the parts diagrams I can't seem to figure out how everything is connected from the inside of the transom to the outside.
1) Is there a gasket or oring that connects sits in between the y pipe and the transom mount?
2) It looks like there is a ring (#71) that would act as the oring/gasket but what is #107? It says through transom exhaust plate, exhaust cover part #0125091 . It looks like that exhaust plate sits in between the y pipe and the connection for the transom mount. But that would block the water coming from the y pipe through the bellows to escape.
Once again I'm thinking/hoping the water is coming from a bad seal of the lower exhaust bellow. But if its not, it's most likely the y pipe but I can't seem to figure out how those parts all align.
See video to see the leak. (Sorry for the bad compression)
https://www.youtube.com/watch?v=hEnlwFDba6A
Let me know if you need more info to answer my questions. I greatly appreciate anyone who helps me out. I attached some pictures to help explain my nonsense.
Vessel is an 89 Bayliner Ciera 2855 powered by an 89 7.5L OMC 460 King Cobra
