trailer angle
tbird175
What is the proper procedure for determineing the heighth of the hitch for a boat trailer? Should the trailer be level while towing?
Docknocker
Re: trailer angle
Hitch should be slightly above trailer axle, and tongue weight should be at least 10% of gross weight. You need to carefully tweak these 2 adjustments until you can tow at all speeds with no trailer sway
tbird175
Re: trailer angle
My trailer has a drop axle. I assume that I should work with the spindle elevation. Right?
Docknocker
Re: trailer angle
Correct - center line of your hubs, which may vary from the center line of the axle itself
tashasdaddy
Re: trailer angle
the frame of you trailer should be level, then you either get a drop or rise tow bar for the reciever.
Silvertip
Re: trailer angle
Agree with Tash. There is no guarantee that the spindle-hitch ball horizontal alignment will result in a level trailer frame. Level the trailer on a flat surface (like a parking lot). Measure from the ground to the top of the coupler. Install a hitch receiver and ball that results in the same measurement. Allow about an inch or two for spring sag on the tow vehicle. Couple up and see where its at. Adjust for level trailer as required.
NSBCraig
Re: trailer angle
Level that puppy!
Whole setup should tow level.
If truck squats you've got too much weight on it and need to reduce tongue weight or get a weight distribution hitch..... or your not using the right size tow vehicle.
But all the geometry and what not are based on everything being level.
tbird175
Re: trailer angle
Thanks for all the information.
