Trailer Axle Arc/Bend
reils_99
I'm looking at a used boat...I noticed the trailer axle has a slight upward bend or arc...almost cresent shaped. The owner says this is normal and called a cambered axle. Is this true or is it bent? I can't find anything about a cambered axle on the internet... could it have another name i.e. torsion axle?
Any help would be appreciated...
Thank you Sean
MTribe08
Re: Trailer Axle Arc/Bend
They are made that way. I put a brand new 3000lb axle on my quad trailer and it had an arc....I also just bought a boat with a dual axle trailer that had arc's in both..I called the trailer company and they said it was intended to be that way to counter the load of the boat. Many "light" duty single axle trailer's are straight. Here are some pictures of my axles..some thought they were bent as well...But both are shaped the exact same way.
http://forums.iboats.com/showthread.php?t=347428
Mark42
Yep, MTribe08 is right on the money.
captharv
Then, my torsion suspension, disk brake, 5200# axles are considered "light duty"; they are perfectly straight.
Mark42
Curved axles are common. But neither of my 2000lbs trailers have curved axles. Just depends on who made the trailer or replaced an axle.
If the axle is normally straight, any downward bow indicates an overloaded condition.
rentprop1
I have a small landscape / utility trailer and the axle is curved like that :D
Silvertip
Cambered axles are very common these days and the theory is that as load is added to a trailer with a straight axle there is a tendency for the wheels to go from perfectly vertical to tilted in at the top. To compensate for that the axle is bent or cambered to have the wheels tilted slightly out at the top when the trailer is empty but perfectly vertical when loaded. Whether or not an axle is cambered or not depends solely on how the trailer is manufactured and its rated load capacity. Torsion axles are a totally different design and use a swing arm at each end.. Each of the arms is embedded in a rubber insert in the axle itself so it is in effect, a rubber suspension. There are no leaf springs.
