saltwaterbluefish
Thread starter- Joined
- Dec 14, 2010
- 156
Got a huge problem. This afternoon when pulling my boat out of the water I heard a rubbing noise and found the wheel rubbing against the fender when the boat was loaded.
I unloaded the boat and pulled up. The tire was no longer against the fender, but the axle has slipped up on the spring and is no longer in the center of the spring (titled at about 25 degrees). Therefore, when the boat is loaded and the spring moves, the tire presses against the fender.
My plan is to cut the u-bolts off and put new ones on, while centering the axle in the middle of the spring. It seems to have only occured on one side, but I want to replace both just in case. Does anyone see any issue with this?
I had to leave the boat in the water overnight. Luckily it is a private ramp and I have a dock space, but still want to get it home ahead of this cold weather that is suppose to hit NC this week. The trailer is an magictrail that holds my 18 ft boat.
I also lost the bearing buddy cap that went on that side. I am guessing due to the vibration when I pulled it out. Anything I should check to make sure the hub didn't get damaged. I am going to buy a dust cap as a temporary fix to get it home.
Any help is appreciated!
