workerbee606
- Joined
- Jun 24, 2012
- 60
I took my new pontoon to the lake this morning , about 80 miles tow each way, well when I got home I noticed some grease had slung out of the right rear hub onto the wheel and the hub/ bearing budy was hot to the touch, not so hot that I couldnt hold it for ten seconds but pretty dang hot. The trailer is new as is the boat and the dealer had serviced it when I picked it up three days ago. The grease was coming from around the little rubber cover that keeps dust out of the grease fitting. I wonder if it was just some excesse grease or a bearing or seal going bad. Both the left and right hub on the rear axle felt the same hot, while the hubs on the front axle felt barley warm, is this normal? The trailer has surge brakes and the trip was faily hilly and I got drove around 60 mph the entire trip. Also the trans temp on my 2011 suburban tow vehicle would get up to 210 on a couple of the real hilly sections, is that too hot on the tranny, I kept it in tow mode the entire time to keep it out of overdrive and help with shifting. The pontoon feels like a tank behind the suburban when I get to highway speed, I guess its the drag from the big blunt front end.
