haulnazz15
- Joined
- Mar 9, 2009
- 3,720
Anyone ever had their trailer bunk brackets (welded) moved to better fit the boat? I have a trailer that I'm switching my 20' v-hull runabout over to, and the bunks don't quite line up with the chines. Basically the bunk brackets on each side need to be moved over about an inch or so on each side. I've taken it to a trailer repair shop, and they quoted me $630+ to do the work @ $60/hr for labor.
I don't see where they justify 10 hours of labor, as the existing brackets can be used, they just need to grind off the welds and re-weld in a new position. 8 brackets will need to be moved. The height is pretty much spot-on, so no adjustment needed there.
Sure, I could grind them off myself and then buy adjustable bolt-on bunk brackets, but I would prefer the cleaner look of the welded brackets. I have a hard time paying twice what I bought the trailer for just to move the brackets . . .
Any thoughts?
Any thoughts?
