Trailer bunks
Brewkrew
Hello, I need help, I have a trailer that I want to use with my 1997 Champion bass boat I just bought and I need the dimensions of the bunks from center and height/angle of each bunk, so if any of you guys have a 18-21 ft and could measure yours that would be great, Thanks in advance.
Brewkrew
Re: Trailer bunks
Hey guys any Champion might work also I've heard skeeter chines/stakes are similar? Thanks
HAV2FISH
Re: Trailer bunks
Ive never had your problem before but ill take a stab at helping you out. Measure from the bottom center at the back of your boat out to the rib where the bunk would sit. Transfer that to your trailer. Now tape a string from one side of the boat to the other where the bunks will sit. Measure from the center of that string down to the bottom of your boat. I would add an inch to that and this will give you the hight of your bunks from the trailer to the underside of the bunk. Just repeat the process for the front minus the string part. Hope this helps.
