Trailer crossmember help
Dennischaves
I have an older shoreline trailer for a 19'boat
The 2 crossmembers that the leafsprings and axel attach to are very rotted
Im going to replace them
They are both 8' long
I can buy 3"x3" steel but should i get 1/8" steel or 1/4" thick?
GA_Boater
What condition is the rest of the trailer? Often when parts start rusting like that, the rest isn't far behind. Tubes rot from within.
If you are going to replace the x-members, go with what's there now.
Dennischaves
The rest if the tailer is pretty good
The crossmemers arent the original ones looks like someone put them on from another trailer
Im just worried about the crossmembers collapsing from being too thin
The boat fully loaded is under 2000 lbs
get a new trailer. the rest of it will soon fail too.
ahicks
If a new(er) trailer just isn't in the cards-
I like C channel, so I don't have to worry about what is going on where I can't see. I'd likely go 1/8".
Old axles scare me too - because you can't see what's going on inside them either....
Dennischaves
Ok thanks guys i didnt think 1/8" would handel the load
Also my rollers have about 1/2" wobble in each direction
Is that about right?
