Trailer issues
limitout
Banned
Re: Trailer issues
you were told wrong... the board gives virtually no support at all past where the bunk support is... you can hang em out there as far as you want but the transom should be right at the bracket if you want it supported
I suppose it all depends on the weight load involved because the board is not just going to snap off like a toothpick so it does in fact have strength and support beyond the bracket support point and just how far out that is going to be depends on the weight of the boat but it isn't much more then a few inches im sure. the larger the boat the more critical it is not to have any overhang of the brackets and the lighter the boat the more overhang you can safely allow. I might go as much as 6" on a flatboat or a boat like the OP has but not a heavy fiberglass hull boat.
smokeonthewater
Re: Trailer issues
the board will flex... the bottom of the boat SHOULD not... if you are flexing the bottom of the boat you are not treating it well
ALUM is less sensitive to a point because it doesn't generally take a set from being slightly flexed but a 2x4 extending 6" will measurably flex from me stepping on it.... I suppose if your boat is 100 lbs all up then maybe but the op's boat is heavy enough that the extending 2x4 will do nothing for it
zippy83
Re: Trailer issues
That said, if I read zippy's question right he was actually asking a totally different question... I beleive he was asking if he could set up a second set of bunks beside the old ones and then remove the old ones after launching the boat
Yes that would be ok but would be a LOT more work than just launching the boat in the yard to put the new bunks on and I think you are probably better off with them inboard of the strakes like they are now
looking at your pic you need to move that boat forward on the trailer though.. you have quite a bit of overhang... not good
Yes, that was exacly my question. I think I will leave the bunks where they are now.. As for the boat hanging a little off that is because I was moving the front roller backwards 12" so the whole boat moved a few inches durring that process. When its all the way on the trailer it sitts completley on the bunks with an inch of extra space on the bunk. I have even made the new bunks a little longer so I may have 2" of free space once completley on it...
zippy83
Re: Trailer issues
ok so just noticed another little problem. When I moved back the roller as suggested I also raised the boat 2" higher, now I cant get the boat onto the bow stop. I cant raise the bow stop any higher. Pictures are attached.
What do I do Now?
Thanks
Zipp
After looking at it some more I could raise the bow stop 2" but I would only have one screw holding it in place istead of two...
limitout
Banned
smokeonthewater
Re: Trailer issues
eh, just step on the tongue, grab the bow stop, n bend it up a couple inches.... If you aren't quite up the the task, find a cornfed country boy to help ya out... If you feel like a 6 hour drive east I'll do it for ya
zippy83
Re: Trailer issues
That is actually not bad idea. I dont ever ram the bow up against it... Usually just crank the few inches manually. I will give it a shot :)
GA_Boater
Re: Trailer issues
If you're a 98 pound weakling :)D) or can't find one of the country boys Smoke mentions, use a chunk of 2X4 and a jack on the tongue to raise the stop a couple of inches.
dingbat
Re: Trailer issues
I was told its ok to have as much as 12" of board extending beyond where the bracket support is and the board still retains its full strength and stiffness
It may be OK as in tolerable deflection, but it's physically impossible for it to keep its full strength and stiffness.
Everything defects, either under load or under it's own weight. For every unit length you cantilever a beam the deflection for a given load increases by a factor of 3. 1 unit =3, 2 units = 9, 3 units = 27, 4 units = 64,........12 units =1,728
BTW: unless two objects have the same moment of inertia and modulus of elasticity the two objects are going to flex separately no matter what do.;)
banshee owner
Re: Trailer issues
what if you just flip the bow stop and crank over or move the bow stop to the bottom below the crank looks like theres another hole below the crank
Grandad
Re: Trailer issues
I would definitely turn the winch over. As things are right now, your winch is pulling downward as you load your boat which is inefficient. Next, I'd improve the bowstop design. Even a 16' boat has considerable weight and momentum if you need to stop quickly or worse if you rear end someone. Ask me how I know this. Anything wimpy enough that you can bend to where you want, will bend wherever it wants, just when you need it the most. You might try something like in the picture below of my setup. - Grandad
limitout
Banned
Re: Trailer issues
if the bow stop is under the bow eye there is nothing to keep the bow in place and it will bounce unless you create a way to solidly secure it from lifting up.
the bow eye being locked under the bow roller is what keeps everything fixed in place.
I agree, that's an excellent point I hadn't thought about, that small flat bar is not going to deflect or hold the boat even in a low speed collision and the winch alignment while not that bad, it still isn't correct and should be changed so its easier and less stress on things to winch up the boat.
he can easily make a bracket like is added to yours so the bow stop can be adjusted to the correct height. this can be done by going to home depot and buying two 4ft lengths of 1/8" thick 1 1/2" x 1 1/2" galv angle iron and drill holes as needed to recreate what you have.
zippy83
Re: Trailer issues
Question? Why use a peace of steal that is in a 90 degree angle? I understand that only one side will have holes that will hold it in place..
Could I use this instead?
Or should I look for a square tube some place?
Re: Trailer issues
Ayuh,.... Because Structure is Strength,....
Flat stock only has strength in 2 directions,...
Angle iron is strong in 4 directions,...
zippy83
Re: Trailer issues
Hello I am not a big fan of using an angle.
What if I could find the same Iron tube that is in the picture provided by Grandad?
I have found a local steel comany that has the following options:
Rectangular:
48"L x .125 thick 2" wide and 1" height
48"L x .125 thick 3" wide and 11/2" height
48"L x .125 thick 4" wide and 2" height
Square:
48"L x .125 Thick 2" x 2"
48"L x .188 Thick 4" x 4"
zippy83
Re: Trailer issues
I also took the advise and turned the winch over as suggested, however I don't think that this will work.. I can crank in but when I flip the switch it dosent lock into place, I have not thought about that until I was done. is there anything I can do? Is that little peace for sale anywhere that will work with this upside down?
so basically I am cranking in backwards instead of forwards...
zippy83
Re: Trailer issues
ok I am over thinking this by a lot. This time I did it right. This is how it looks now. Still not 100% leveled but looks to me better then it was before. If it needs to be more up I could probably find some 1/4" thick steel that I could bolt on an extension about 2" if need to be. That would give me one bolt in the main post and the other on the extension.
Thanks
Zipp
