Trailer Jack
agallant80
Just thought of this. My boat is 7K dry and the trailer is 1500lbs. So about 9K with fuel etc. How large of a jack would I need to jack this thing up if I get a flat tire? I doubt the jack in my truck will lift it.
Re: Trailer Jack
Ayuh,.... I can't feature that it Wouldn't.....
If it's a tandem wagon, there ain't more than a ton on any 1 point you'd be liftin'....
tazrig
Re: Trailer Jack
My rig is just a little heavier than yours, not by much though. I use a 3 ton sears floor jack (over kill but fast and easy to use) I bought for $80 on sale. you can find them smaller and cheaper too. For when you are out on the road if you are a member of Boat U.S. you can add "trailer assist" to your membership for I think $14 annually. (think AAA for trailers and tow vehicles) They will rescue you 24/7 with no co-pay and if you don't have a spare with you they will tow the boat and your tow vehicle, if needed, to your house, or boat yard. Pretty cheap coverage for what they offer. JMHO
EddiePetty
Re: Trailer Jack
Well....I wouldn't believe you would need a jack of much greater capacity than the load rating of your trailer tires.
Your truck jack should suffice providing it will fit beneath the axle adjacent to the future flat. :)
Jake007
Re: Trailer Jack
If you have a tandom axle you can also use a couple tricks I have used in the past. My truck jack could not raise high enough so I broke the bolts loose while on the ground and drove over a culvert area just enough to give me the clearance to change the tire, no jacking necessary. Another time I backed onto a curb with one of the tandom wheels and was able to change the other tire with no jacking.
H20Rat
Re: Trailer Jack
I carry a couple chunks of 4x4 in my truck... I don't ever need a jack for the trailer... I use the wood blocks the same way as Jake used the curb... Also they make a tool specifically for trailers that lift the axle by moving the vehicle
Seasense, 50080578, Trailer Parts, Trailer Jacks, Seasense Trailer Jack, Easy Lift 50080578 - at FirstChoiceMarine.com
Although I wouldn't recommend it, i've done something similar to that gadget with a 2x4... It was about 16 inches long, perfect length that if you wedged it against the axle and the ground, it was about a 45 degree angle. From there, just put the vehicle in gear and GENTLY move it forwards a couple inches. And the key part.. Never, ever get any body part below any part of the trailer, EVER!
lncoop
Re: Trailer Jack
I second the Sears floor jack. Quick and easy and doesn't take up a whole lot of space.
Captain Caveman
Re: Trailer Jack
I keep an old bottle jack in the bed of my pickup along with a couple of 2x4s and 2x6s. You never know when you'll need the extra clearance or stability when jacking in the mud or snow.
smokeonthewater
Re: Trailer Jack
Ya, know..... I just thought of something.... if yer tow vehicle jack can't lift yer trailer.... ya MIGHT oughta consider a bigger tow vehicle LOL
hungupthespikes
Re: Trailer Jack
I use either an old cheap floor jack or a hydraulic bottle jack (from junkyard) and always a jack stand.
A truck/RV junkyard will part with the OEM hydraulic jacks, the smaller/auto yards not so much.
Here's another option. Several different ones out there.
