I'm wondering if someone can help me trouble shoot an issue with my trailer lights. I've got an old Alumacraft fishing boat on an old trailer. The lights are similar to if not these exact ones https://www.etrailer.com/Trailer-Lights/Optronics/TL5RK.html. Last year I replaced the whole left tail light as it was smashed with the exact one that was there before and everything worked. This year, Right trailer light was out. Everything else worked. I swapped the bulb. Was checking lights with the truck. They were on, signals worked, brakes worked except right one didn’t get brighter when pressing brake. Asked buddy to press again. Then the whole trailer went out and hasn’t worked since.
Fuses in truck are fine. I’m getting current at the linkage. (I've got a converter that changes it from 7 pin to 5 pin and it lights up when plugged in)
Thought it might be the ground wire by linkage so I sanded it to bare metal put dielectric grease on it. Still doesn’t work.
The left tail light I installed last year has ground wire installed. Right one (old preexisting) does not have a ground wire on it. I don't know if the previous owner cut it off. IT worked fine without one and even with the bulb out until I tested it.
I matched the bulb I bought to the closest similar one I could find as it was really old so I don't know if it could be that bulb? However I don't know why that would cause all the trailer lights to go out.
Some help would be much appreciated. Thank you!!
