Re: trailer lights
Add a ground from the lights to the plug? I'm so sorry I'm just not picturing it.
Where the lights bolt to the frame and or mount, there is or should be a wire to ground the light. Extend that wire to go to the ground prong in the plug on the trailer side so you dont have to worry about a bad connection to the trailer anymore.
If there is no ground wire, you can: 1 take the lights apart and add one or, 2 clean the mounting bolts (thats where they ground) and add a wire from the mouning bolt to the plug so you have a direct ground and again bypass the trailer for grounding.
At the very least, clean the light mounting bolts, and where they contact the trailer, then add a wire from the trailer to the White wire from the plug to the trailer frame.
