trailer locking system frozen
rzkas
hi and how are you? on my hitch i had a lock instead of a pin. after docking the boat in salt water all last season, i tried to unlock the lock but it is frozen. i kept trying to the point i partially broke one of the key but still have one good key. the key did not broke inside the lock but i can see that it broke partially. what do i need to do to brake the frozen salt or rust salt inside this lock because i want to remove my hitch from the truck but i can't until i remove the lock. any idea how to go about unlocking the lock or removing the hitch. i have the "master lock". thanks
Dick Bacon
Re: trailer locking system frozen
A good penetrating oil sprayed inside the lock should break it free. PB Blaster is some good stuff.
Thalasso
Hi!!
You have to back your trailer that deep? Might as well get a die grinder and cut it off and buy a new one. Keep it lubed if your in salt.
rzkas
i tow my boat with my savana van and it low
H20Rat
Drill the lock out
way quicker just to take a angle grinder with a cutting blade. Drilling locks SUCKS, especially if you have a key in it and you can't put the lock in a bench vise to hold it still. They obviously are made of fairly hard metal, and depending on the construction, drilling it out may not even open it up.
jeeperman
two pound hammer and beat the hell out of it.
ufm82
Air or electric grinder or the venerable flame-wrench...
oldjeep
Good luck getting a grinder in by the hitch pin without hitting the hitch - been there done that, bought the tshirt. If you have decent bits you can drill a lock out in a minute or 2. Personally I use a plasma cutter when I'm at home ;)
T_Herrod
Soak a couple of large rags in water and wrap them around the trailer hitch ahead and behind the lock. Get a torch and cut the lock off. The wet rags will keep the flame and heat from the torch from damaging the hitch.
lckstckn2smknbrls
This might be a good time to drop the whole hitch. Then you can cut the lock off, grind off any rust, repaint it and reinstall it with new hardware.
nlain
If you use the cut off wheel method go to the opposite side and cut that end off, I think there will be more room that way.
cribber
Like everyone has said here... cut it off with whatever means is available to you. I use a laminated masterlock on my trailer and have to spray it occasionally with WD40 when it gets tough to open.
