Trailer Maintenance
Mordekai
For the tahoe trailer specific maintenance, What do you all do?
Last fall I forgot to pump fresh grease into the axle but this seems a bit of a mystery to me still as I don't see any fittings there I can fit this tiny tube of the grease gun into.
Can anyone have done this give any insight?
Thanks
Paul DuLaney
Re: Trailer Maintenance
Does your trailer end cap have a rubber plug on it? If so use a small screw driver to work it out and the nipple is on the end of the axle.I put a lot of grease in so to work out any MOISTURE out,I do this when I winterize to make sure no moisture it in before it's put away for the winter.
Mordekai
Where does the "bad" grease come out? I'll do the exploration today when I get home.
splicer
You'll see it work out around the outside of the hub. It's not difficult.
Right break
Tip! Wipe up whatever grease comes out before driving. It will sling all over your wheels and its nasty stuff.
KBD431
I've done the axle but I also noticed nipples on the tongue swing hinge and the two tongue roller pins. I did the swing hinge until I could see old grease come out and I did the two on the roller pins but could only see old grease come out of one. Am I missing something?
grendelsniper
I grease the axles and adjust the brakes, check fluid in master cylinder, done
