Hi,
Here is what I am working on. My trailer is best suited for glassfibre and aluminum boats - not so much inflatables. So, I must mod it to suit my SIB a bit better.
Main problems:
1. rollers really do not handle the SIB gentle enough
2. front rubber bit also more suitable for other kind of boats
3. fender steps too sharp
#1 being the biggest problem.
So, first of all I swapped the front V-rubber to slightly less agressive one. Still going to add some neophere or something to make it softer. Old and new rubber together:
Then the fender step part, got to get some soft stuff to cover this:
And then to the rollers and the actual platform for the SIB.
First of all, start up point:
1st step: remove rollers and the part that flips up:
Then try to figure out the correct level for the wooden frame and rails:
And then draw up a plan:
I've never hauled SIBs with a trailer before so I am not sure what is the best solution for this. I have examined all inflatable trailer pictures I've found in the forum and basing the basic design on what I have seen.
Should the wood rails be covered with some protective or more slippery material?
So, all comments and suggestions are welcome.
Main problems:
