trailer problems
Asylum
i have a 1984 17' mako ....the trailer is a sportsman model 17LR
it has bunks but also a raiseble roller system 2 rollers forward of axle one just behind the axle and one at end of trailer...these all lift up with a lever at side of trailer...the trailer also tilts
what are the easiest launch and retrieve technics for this type trailer???
thank you in advance
tashasdaddy
Re: trailer problems
as long as the ramp is deep enough float off, the rollers help center the boat, so should be use when loading and lower when towing. take the weight off the keel. if you put guide ons on the trailer, and float on you don't need the rollers.
