Trailer sounds like chain is dragging but nott
HoosierHacker89
I have a fairly new to me trailer and it is making an odd noise at lower speeds. Like it is dragging a chain, but no chain is being dragged. Suggestions on what to check? Trailer is 2009 shore land r. Basic “T” style I’m sure this is not the proper term.
briangcc
Bearings / brakes.
Had a bearing go on an Escort trailer. Didn't know it at the time but at low speeds, the trailer shook hard enough the trailer jack would rattle. Died down at higher speeds - go figure.
This was way back in my younger/stupider days. Cost me an axle by the time I had the marina check it out - boat & trailer was basically new.
airshot
Jack up each side and spin the wheels in both directions as well as checking for play. Otherwise.....is something loose that chatters when going down the road ?
cyclops222
Speed dependent noise vibration should be wheel bearings getting ready to break completely.
HoosierHacker89
I jacked my trailer up and spun the wheels in both directions. They both spun freely and had no play in them. Plenty of grease in each dust cover. I’m thinking noise is not bearings. I will replace bearing very soon. I don’t have several pairs of gloves at the house to pull apart to replace. I’m going to take the back up safety chain I installed (to keep bow down if winch strap breaks) to see the slack in that is causing the noise. Thanks for the suggestions so far. Will update thread.
mike_i
Does the trailer have brakes? If so have you checked to see if they or hubs are getting warm?
HoosierHacker89
No brakes on trailer. It’s one of those little 2 wheel 2 hundred lbs ones. I will check hubs.
HoosierHacker89
Replaced entire hubs. Still same noises. It occurred to me what was making all the racket last night.
HoosierHacker89
It was quite obvious to me once I finally saw it. My old trailer didn’t not have anything like this on it so, so noise like this was made
