Re: trailer sway at 60
Usually trailer sway is a result of two little tonge weight. Recommended tounge weight for boats is 5 - 7% of the total towed weight. I was having the same problem with my 23' walkaround on a tandem axle aluminum bunk trailer, towing with a Ford Expedition. I went to a public scale, checked the total weight of the trailer and the tonge weight, adjusted the axles and boat position to obtain the correct weght (heavier tonge weight favoring the 7% based on the calculations). The problem went away and I can now accelerate to 70+MPH when passing without any trailer sway. I usually run at the speed limit (65) on the interstate with no problems at all. Also when you load the boat for traveling, you need to balance the item position in the boat so as not to throw off your tonge weight. I usually load a little more in the cabin which makes it a little bow heavy. I also added Air-Lift air bags in my rear springs and inflate them to the rcommended 35 lbs when trailering. Even if your tonge weight is correct, if your tow vehcle sags when you put the trailer on it, that will effect your steering and increase possibility of trailer sway. Trailer Boat Magazine and their web site has a lot of good information on setting up a trailer and tow vehicle. Good luck.
