Trailer Tail Lights Not Working
Frank Chyz
Brake lights and turn signals work fine but tail lights do not come on. Same problem with a box trailer I pull from time to time. What should I be looking for on the truck side of things?
dpoff
I guess get a test light or volmeter and test the connection on the truck, should be the brown wire, then go from there.
sublauxation
You can get a 4 prong tester for a couple $ or as mentioned, just use a volt meter or test light. I've had to replace more than a couple truck end plugs in the past years.
Cat nip
If its a Chevy it mite have trailer light fuses in the under hood fuse block .
NYBo
Good call. Actually, many (most?) trucks have separate fuses for the trailering harness. My '07 Dodge Ram does.
Silvertip
Honorary Supreme Mariner
The brown wire in a trailer harness is the tail lights. No power at the plug, check the fuse. If the fuse is ok, then the wiring is buggered.
Silvertip
The brown wire is the tail/running lights and runs from the trailer connector to a point where it splits and runs down both sides of the trailer. Think of that wire as a pipe with water running through it. Follow the juice with a voltmeter or test light. When you lose the power you found the problem./
Ironic
I've run across the same problem with my trailers. In my case, I kept blowing the fuse in the fuse box under the truck's hood. Your truck's owner's manual will tell you which fuses are for your trailer lights.
I later found that I had a bad ground in my truck's trailer plug recepticle. I changed the "outlet" and haven't had any problems since.
Whatever1969
This season mine weren't working either. I ended up chasing the wiring and discovered that mice had eaten the insulation off of them. They were shorting against each other and the trailer rail.
